Dynamics II - working or not? 8.0.1
Dynamics II (and eq II) disappeared from 8, wouldn't even load and were moved to unused by PT, so we stopped using them. This was a pain due to years of sessions that used them. However, it seems to work again in 8.0.1cs1, loads up and is fully usable in the session. Great News! Was this included in a CS update?
I realise it's not officially supported but given it's a digi plug is this "safe" to use in sessions or am I likely to run into plugin related weirdness and issues? I know the party line on only using compatible plugs.... |
Re: Dynamics II - working or not? 8.0.1
it's installed to the Unused folder to try and get people off of it but it there if you need to recall an old session.
now if the could make a 2 to 3 converter..... |
