Trouble with pro tools 7.4.2 and Mountain Lion osx 10.8
I have the digi 003 with LE 7.4.2 software. I upgraded my mac to mountain Lion 10.8 and now none of my recording drives can be set to record now. I get a prompt and it says it is not a valid recording drive. Even my mac HD can't be set to record in the workspace section. I desperately need to record what can I do? Do I need to up date my software some how? Please help.
Thanks, John |
Re: Trouble with pro tools 7.4.2 and Mountain Lion osx 10.8
Where do I buy this? Is it available online from avid as a download or do I need to get it from a music store? Hope its not too expensive...:)
iLok v2 You can run Pro Tools 11 as a fully-functional demo for 30 days, so you will not need the iLok v2 right away to launch the software. If you have any paid plug-ins, then getting those working will require buying upgrades, etc. |
I haven't checked the specs, but I highly doubt PT 7 is a good idea with Mountain Lion.
You need to update to 10 at least, or you are in for a world of hurt. Try reformatting a hard drive with the current version of Disk Utility. Then see if you can toggle to rec drive. kasper (I see the Chief has beat me to it ..... oh well, you'll probably have to reformat anyway) |
where are these upgrades available from? Can I upgrade from 7.4.2 to 11?
I see upgrades from 7.4.2 to 9 and from 10 to 11 but nothing from 7.4.2 to 11. Any advice?
To clarify a few things:
You upgraded to Mountain Lion without thinking about whether your software was compatible. 7.4 is not compatible with Mountain Lion, or even regular Lion. In the future, you'll want to check things like that first. I don't know if it's possible to downgrade your Mac back to what it was before. If you can't, then you will need to purchase an upgrade to the latest version of Protools, which is 11. This also gives you a license for 10, which is useful because not all 3rd party plugins are ready for 11 yet. In fact, you may need to pay to upgrade some of your 3rd party plugins to be compatible with both Mountain Lion and Protools 11/10. The upgrade you need is the LE to 11 upgrade which is $399. It requires the hardware serial number of your 003 to qualify. Also, since PT9, Protools requires an Ilok to run. You will need a version 2 Ilok specifically an Ilok v.2. This is about $50. Alternatively, if you play guitar, you might just want to get an Eleven Rack, which includes PT11/10, and includes an Ilok 2. You can get these for about $639 at Amazon or B&H Photo. That's less than $200 more than buying the upgrade and an Ilok 2. |
Thank you for giving me an answer that is clear. I had to upgrade to osx 10 to use final cut pro X I didn't think it would kill my pro tools. This really sucks because i had my system all set up working exactly as I needed Now I have to spend over $500 just to get my system working again! I am truly disappointed!
Disappointed in what exactly? Program stops working with Newer Os's all the time and vice verca, you even state yourself that you had to update your OS to use a certain program, that should give you enough clues that you should maybe make sure of what will happen if you update your os next time. Having to fork 500$ or more for something you should have checked first is not fun, but on the other hand if you go with the idea proposed for the 11rack, you don't just get a software, you get a hardware too, that has I/O, mic pre, good guitar amps (and bass amp) emulations. So all in all, it's not a bad thing.
