some general PT questions
1) i have f.ex drumsounds , placed in quartes , tempo f.ex 110 . now i change the tempo f.ex to 120 . how do i tell the drumregions to stay on their destination meassures ??? is there a way to quantize audiofiles ( pt 5.01 ) .
2) rerecording a track takes how many samples ??? 3) a insert takes how many samples ??? 4) is there a add on tool where i can load my sounds and AS plugs into and tell it f.ex ... soundfile a-d processing with pluginchain xy soundfile e-g processing with pluginchain xx ( worklists ... ) if not it NEEDS to be programed !!! ( cant be that hard ) 5) how to configure the mac running PT AUDIO & LOGIC MIDI ??? if running 2 MACS will those programms exchange infos f.ex looped selection ( via machine control ) ??? someones doing it ??? 6) if i have f.ex a bassdrum cutted during the whole song , is there a way to tell PT to place a f.ex a second sound on every bass drum hit ??? or still doing it manual ??? 7) is there a shortcut for creating new playlists for the whole session . lets say 20 tracks , i press a key and all the tracks appear in a new playlist ??? or do i have to create playlists manual for every single track ??? 8) if i have a region f.ex a drumloop is there a way to cut the whole thing in 16th with one click ??? ( depending on the session tempo ). works in logic !!! works in pt ??? 9) can a 2 or 3 buttoned mouse be configured to controll f.ex the toolchanges etc ??? i know some of this is in the manual , but i know some of you guys have some great tips . so please respond . i am fine with PT just trying to find a way to make it FASTER [img]images/icons/grin.gif[/img] thx you , merry christmas |
Re: some general PT questions
nobody ??? THX YALL [img]images/icons/grin.gif[/img]
I'll take a stab at a couple of your questions. Some are a little hard to understand.
3) a insert takes how many samples ??? If you are talking about insert delay, you can find out to the sample by clicking+Command on the volume box just above the pan on the Mix page. It will cycle through peak/delay/ and back to volume. 9) can a 2 or 3 buttoned mouse be configured to controll f.ex the toolchanges etc ??? I have a five button mouse which works great for PT tool changes! Also, the Shuttle Pro (from Contour) is very cool. Lots of programable buttons and jog/shuttle. If I understand you, Sound Replacer could answer question 6. |
Post deleted by Digidesign
ok 1st of all , thx a lot [img]images/icons/grin.gif[/img]
trying to explain the " hard to understand " questions . 1)f.ex. a cutted bass drum sound , sessiontempo 100 , placed on the bar 10/0/0 . if i change now the sessiontempo to f.ex 120 the soundfile stays on its destination place , but not on bar 10/0/0 . thats somehow logical cause all it does is to expand or compress the sessions lenght . but i would like to know if theres a way to tell the audioregions to stay on 10/0/0 when i change the tempo . right now it comes to my mind that the " lock audiofile " may work ??? gonna try it later . 4) soundprocessing question : to add inserted effects ( like dynamics , eqs , etc ) to a audio file is either : bounce to disk or the audiosuite dialog . the good thing about bounce to disk , you can add more effect than "1" during one bounce . the bad thing , it takes the realtime of the files lenght . the good thing bout AS , its faster . the bad thing only "1" effect can be added during one process . if i have now f.ex 13 drumtracks and made my pluginadjustments ( saved all the particular pluginsettings , [ a button to save the whole channel pluginchain would be more than awesome ] ) now i am asking for a "TOOL" where i can load my 13 drumtracks into . tell the TOOL , this sound should be processed with those plugins and this sound with this etcetc . something like a worklist . after this i hit the "doit" button , gonna get a coffe and come back . 2&3) i know that the delay compensating tips are in the manual . but sometimes i still get that nasty filtered effect following the manual . f.ex two recorded files , some comps on the channel inserts , sending it to a bus with a eq , a master fader to control the levels , using a analog chain as well and rerecod the file . [img]images/icons/mad.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/confused.gif[/img] auto delay compensating would be wonderful , but that has been discussed quiet often . i thought some of you PT gurus now it out of the head or have a sample delay list at the computer . 6) i tried soundreplacer and it didnt work that great imho . it needed to be edited manual . i know that pt gives the regions a timestamp . this infos is saved with the session . i just wanna bring in some sounds and tell em to use the same time stamps as f.ex. the bass drum hits . ( should work with cutted files ) . but how can i do that ??? 5) logic midi is great , the audio is not that great . protools audio is great , the midi is arghhhhhh . exporting midi into protools is an ok option . but stuff needs to be changed all the time . i am used to both programs . my dream would be either 2 macs ( 1 running pt , 1 running logic ) or 1 mac and 2 screens ( 1 for logic 1 for pt ) . the 2 mac solution may not playback loops ( if i create a loop selection in pt , will the 2nd mac running logic lock that loops as well ??? < machine control > ??? ) . and it may have some sync delay which isnt that great . the advantage would be more slots to have f.ex a soundcard in logic as well to have some softsynths or some samplers . why do i wanna have that ??? cause its more easy for me to work with . i am getting lost if i have 50+++ tracks on one screen . its somehow easier to focus . submixes in pt and importing them into logic doesnt make me happy at all . why ??? easy , if i wanna do some strings on a mixed playback i need to change the levels of the playback before the string will do what they are there for . if i cant change it during the process of creating i am doing to much " useless stuff " in the end . so having this option with two macs and i really would fly . [img]images/icons/grin.gif[/img] thx yall more input please |
Question....what are "cutted files" [img]images/icons/confused.gif[/img]
7 - not a single key.. but simple enough to change mulitple tracks.. either group them, or use the Option+Shift modifier on the Mac or Alt+Shift modifier on the PC.... which let you do lots of functions to multiple selected tracks. (That's also in the manual BTW).
(Re "cutted files") - I believe English isn't his native tongue... so I believe he means edited files. Rail |
thats right rail [img]images/icons/grin.gif[/img]
sometimes its a nightmare to understand what you guys are talkin bout . i am glad the duc isnt in chinese . [img]images/icons/grin.gif[/img] and again , more please ... " is it that hard to understand " ... [img]images/icons/confused.gif[/img] peace |
