Metronome program
Hey all,
I am trying to find a good metronome program that I can run within Pro Tools LE 5.3 on Windows XP w/ Digi 001 interface. I found one that looks good however it only runs on Mac and haven't had any luck. The program would have to be able to set up different times per measure or be able to create loops with odd-time capabilities. What are you guys using with your systems? Any info is greatly appreciated? Thanks, ~Mike |
Re: Metronome program
I'm using the Click plugin that is included with PT version 6.1.1 and it does everything that you want it to.
I know that doesn't help you much with 5.3, but along with a lot of other new features, it's a great reason to upgrade. |
Ummm, maybe I'm missunderstanding, but there's a metronome in PT's.
Create an Aux (or audio track). Instantiate the Plug'in called Click (should be at the top). In the Transport, click the little metronome icon in the midi section (if you don't see the midi section - display/transport window shows/Midi). In the plug, click factory default and you'll see your choices (even has the old Pong sound!!). The click will mirror your meter settings and is controlled by your click options settings under MIDI. Hope I understood correctly. Ter |
It wasn't in 5.3?
Sorry, spk is right then, upgrade. |
