does digi002 + 7.4 LE provide lower latency than 64 samples?
the smallest playback buffer size you can set on PT7.3 with digi002 is 64 samples.
I'm wondering if 7.4 can provide a smaller value, like 32 samples for examples. if not, is there other digidesign hardware that does it? 003? mbox2 pro? Anybody knows about that? matteo |
Re: does digi002 + 7.4 LE provide lower latency than 64 samples?
I thought I saw a post on the Mac side here where 32 is now a option with the 002, 003 ETC. I can't find it now. The buffer is determined by the type of interconnect (USB vs Firewire) more than it is by the model of interface MBOX, 002, 003 although there are a couple minor differences at higher sample rates between the MBOX2 Pro and the 002-003 series stuff. But I think 32 may be a new option. The Windows side was limited to 64 on 7.3
Now that we have fast machines we need to have a buffer of 32 available at all of the sample rates |
anybody having 7.4 and digi 002 can check this?
Yup. The 7.4 / 002 combo provides a 32 sample setting. Can't comment on how well it works, but it is there.
MR |
well, thanks for the reply, i've just upgraded to 7.4 on my PPC g5 running 10.4.9 with 002 hardware.
It works great so far and the 32 samples buffering option is a great implementation, now you can track virtual instruments and guitar amp simulation plugs with very little latency, way better than 64 samples! |
