midi setup
Ok, here's what I got:
-masterkeyboard (1 midi in|out|through) -module XV3080 (1 midi in|out|through) -Alesis DM4 (1 midi in|out|through) -PC with Logic audio; I'd like to use logic as a module using the B4, pro52 and Exs24 and the ev88 (vst)instrument plugins (1 midi in | out) -I've got an Opcode Studio 64x midi-interface connected to a G4 with Protools TDM (4x midi in | 6 x midi out) Can anyone help me to get the best setup here, atleast the most permanent one without switching cable etc. Thanks in advance Remco |
Re: midi setup
well .... just connect everything in/out with the studio 64 ..... for example :
masterkeyboard : in/out 1 Roland XV : in/out 2 etc .... and then you have to decide wether you want to run logic using OMS or its own midi protocol. create a basic setup .... very easy with OMS for example .... just follow instructions in the manual and you should be ok. good luck |
Re: midi setup
Thanks (dank je),
It looks really simple that way, I made it sound harder than it really is. Remco |
Re: midi setup
definetely, the so called "hand shake" is the way to go with your set up. good luck
