Of digi 001 and type 12 errors...
Greetings,
I am currently using (or trying to use) Pro Tools LE 5.0 with a digi 001. Every time I try to load PT, I get a crash at start up with an "error type 12" message. This typically occurs right after having loaded OMS, sometimes while loading machine control. Occasionally, it will freeze while loading RTAS plugins. I also own Logic Audio, which doesn't crash, but instead warns me that "no output drivers are available". A friend of mine running exactly the same system has the same problems. The only solution we found is to erase PT and all associated preferences and extensions and reinstall the whole thing. PT (and Logic) then work fine - until we turn off our computers. Upon reboot, the problem is back. Our systems are as follows: Dual G4 @500 MHz 512 MB RAM MAC OS 9.2 (Japanese version) Any help would be greatly appreciated. |
Re: Of digi 001 and type 12 errors...
http://answerbase.digidesign.com/detail.cfm?DID=3709
http://www.digidesign.com/download/protools.html You should be running at least Pro Tools 5.0.1, which was a free update for all v5.0 owners. Or you can upgrade to 5.1.1 for $50. (which also allows you to use the PT LE 32 track version) If you don't have the 5.0.1 CD, try the download of the driver first, and then you may want to check with your local Digi office to get the 5.0.1 update. Also, unrelated but since you are using a dual-processor cpu, you might want to download the Apple Multiprocessor extension: http://www.digidesign.com/download/mp.html This will allow you to keep the multiprocessor function enabled on your Mac, in case you want to use it with Logic or another application that utilizes the second processor. |
