Elementary question: Levels
Hello,
What's the best way to bounce with appropriate audio levels? Currently I'm aiming to have my loudest tracks at just below the 0 mark on the meter. Is this the correct way to do things? Thanks |
Re: Elementary question: Levels
The ultimate answer is, does it sound ok? If so, then the levels are fine :) For a reference point though you should be looking at using a master track to control the overall level that's leaving your system. Create a master track and watch that level over your track ones. So long as your tracks aren't clipping then you can use the master track to get a nice loud mix. Also worth remembering that the PT system gives you lots of nice headroom so you don't need super hot levels to get a clean mix, I can't remember but I think -6 dB is a good reference, I'm sure someone will be able to tell you for sure on here. Also, you can then master your bounce down to bring the overall level up and multiband compress it etc, much harder to remove distortion later on! |
A little deeper into it. I recommend always recording at 24 bit as it gives you much more headroom. Then aim for input levels just into the yellow(no need to go as hot as possible as you are not trying to mask tape hiss, like in the old days). Use a MASTER track so you can spot mix buss clipping(its possible to clip the mix bus with a ton of tracks that are all in the safe zone). Mastering engineers want a final mix that peaks at -6. That will not be a "loud" mix(making it loud is part of the mastering engineer's job). If you are not using a mastering engineer(due to budget or simply that your not expecting that project to end up as a commercial release), then its not too difficult to do your own rudimentary mastering, but that is a separate step/process and you should do some research on that for more advice and recommendations of mastering plugins. Mastering is part art and part science and mastering engineers will get better results than you or I will, but we can still make a loud enough product to make the final product not get lost in the volume wars(the DAMN volume wars). Just don't destroy the dynamics of your music in the process:D
Drummer-"what do you mean DYNAMICS? I'm playing as loud as I can!!!":D |
Also remember, -18dbfs + 0 VU (depending upon your calibration):-)
For a mix..peaking anywhere around -6 dBFS is good. As long as no plugs or tracks are peaking you should be in the clear printing a mix anywhere under 0 dBFS although leaving 3 to 10dB of head room is recommended. |
Your sound will sound the same at any level. The lower the level the higher the noise but you have tons more headroom on digital than you had with analog tape. Noise was around -65 db. With 24 bit digital, -144 db.
Give yourself plenty of headroom when tracking and mixing. Don't "tickle the dragon". Use a meter plugin where you can adjust the operating level. Most agree on -18 dBFS = 0VU. |
