Reveb as a send,
Can sumone explain to be how to use my reverb as a send track> i dont use this in my insert option in any program i have used, but in Pt i cant figuer ou how to make my verb a send instead of an insert, can anyone help?
Re: Reveb as a send,
Create an aux track, insert the reverb there, choose any bus as input.
On the audio track, choose the same bus as a send. you'll get a fader (if not, just click on the send), turn it up. OR Set the audio output to the same bus that's the aux track input. |
I did do this, but it does not allow me to use Bus as an option? Its just, not Higlighted like it normaly would? any idea
Check you I/O set up-set them to default & check again.
When i set up Pt. I put it as default, im not sure how its suppose to look? But i will give it another try after tonight session, i dont want to unexpecticly mess sumthin up! Thanks tho i will check and post back the results
I set up the I/o and i go it, sumwhat. still cant understand exactly what im doing but i will get it!
Stiff spelled it out pretty well but this might help also.
Ok, i was doing it a lil wrong, i understand now, that tutorial cleared it up for me, sorry bout that phellas!
