Avid Pro Audio Community (http://duc.avid.com/index.php)
-   Windows (http://duc.avid.com/forumdisplay.php?f=93)
-   -   MBox Drivers with ASIO4ALL (http://duc.avid.com/showthread.php?t=344329)
mbahnmil 09-10-2013 10:19 PM
Do I need to install the MBox drivers if I am going to install the ASIO4ALL on Windows?
Thanks!
albee1952 09-11-2013 06:39 AM
Re: MBox Drivers with ASIO4ALL
I would. ASIO4ALL is not a great driver, but it can be the difference between something working or not. Assuming you are installing ASIO4ALL so you can work with the onboard audio while traveling? When you use the Mbox, you want the best performance possible, and A4A is not the way to get that.
