Re: Mac Pro/HD3 boot-up problem
hi there,
happy to read that I´m not the only one... I got the same problem on my Mac Pro with HD3 - found out that everytime I´m booting with core card after shutdown Mac and Power of the studio Mac would have serius booting problems (red lamp alarm on the motherboard P-CU B. If I got it to run the cards work with no problems. I just got the call from the Apple service that the got that problem with my core card in several other Mac Pros, too - so I guess, since the system is running in general (friends systems do) - that the core card seems to have a powerup problems. Maybe there are several core cards out there who do have that problem - so check with digidesgn... All the best - and after all lots of good music!-)) Carsten Schmelzer Berlin |
Could there in fact be a compatability issue?
C - We're looking into this, but I have a suspicion it's already been evaluated by engineering.
On the other hand, we do have some other clues. I'm wondering - anyone having this problem, do you have any powered USB devices connected, especially to the front USB port? If so, does disconnecting them help at all? |
Port 1-USB KVM Port 2-SELF Powered USB hub with 2 Iloks, Fastlane USB Midi Interface, and an extension cable going to another Self Powered USB Hub with a Command 8 and an extension going to ANOTHER powered USB Hub with a mini keyboard/trackpad. Also, to update my current situation: Since a P-Ram clear I haven't experienced the grey boot screen. I DID however have 3 kernal panics in one day (the last one with no apps running). I Then ran Apples hardware test, checked permissions and ran Disc first aid. All these found NOTHING wrong, but I haven't had another kernal panic since running them. all very frustrating, since I sure they'll return at the worst possible time. Tim |
There are no USB devices pluged to my front panel - in fact I disconnected all USB and Firewire, even the Monitor from the Mac and it wouldn´t help.
Just got the information from an apple support guy that there might be problems with certain Mac Pros (I think he said ...made in Europe) Digidesign said they tried changing core cards with no help on these Pac Pros - so will we all get new Mac Pros to be able to work with the core card?! arrrrrghhhhhh Carsten |
I have no USB devices on front (and no Firewire at all) and just 1 iLok and keyboard/mouse chain on back.
I've just upped the memory on my machine (quad 3GHz HD3 running OSX 10.4.9, ProTools 7.3.1cs2) from 4x512MB modules to 4x1GB + 4x512MB modules (2Gig -> 6 Gig) and the booting problem is Loads worse. I took it all out and reseated it just in case but no luck. This of course may be some bad coincidence... |
FWIW, I have *not* seen this behavior since applying the 10.4.9 system update, which was around the time I installed a WD Raptor 150-gig as the boot drive. One or the other change seemed to fix the issue. |
Was having similar boot hang issues/date resetting (my nvram battery tested fine) which I posted on earlier in another thread -- I posted my "crash log" and Tech Support recommended removing my Belkin Powered USB Hubs -- After I did this I no longer experienced crashes -- I had two Belkins -- One going into a Gefen HD Extender and another connected directly to machine... Thought this might be of use, apologies if it was not... |
