Re: Are Busses at the App or Session level?
You can always try it yourself, don't believe me. My own experience has shown that less bussing I use the more open sound I get.
Yep counting stems, it's easily 15+, you know I have VCA ability with my license but I always have used AUX's....... |
What you say makes sense on an analogue console - more bits of wire to go through - but in the digital realm it makes no sense at all as it's just maths...i.e. 2+2 is 4, but so is 1+1+1+1. |
The great thing about using Pro Tools is you have flexibility to work however you need to. I could go into my bus layout if that would interest anyone, but I'd probably put you all to sleep! LOL |
Could be wrong I guess. |
???? Are you absolutely certain? Placebo effect is very strong, and I will be the first to admit I've fooled myself more than once.
The summing is at least 24-bit floating point, might even be 48-bit (not sure how they do it), and only the least significant bit would lose resolution. Can you really hear the loss of one bit in 24-bit audio? Or 48-bit ??? Quote:
I'm not saying the different decisions you make based upon how you choose to use Aux Busses won't change the overall sound of your mix. I'm saying, on a 1-1 mix the number of Aux Busses you use are truly and completely irrelevant. I separate my mixes into song segments using Aux Busses for organisation. Outside of that, whether I mixed through busses or not, my mix result would be the same. Clipping an Aux Buss or clipping the Main Out are at the same level, regardless of how many extra Aux Busses you have. There is a reason that Gain staging is so important... |
As I understand it, now that PT is floating point, none of the internal audio should clip. Only at the output when sent to the D/A converter. Am I misunderstanding that?
The old days of fixed point audio are gone. Alleluia. Quote:
