Pro Tools 12 and slow Graphics
Since I have installed Pro Tools 12, the GUI gets very very slow, and lags a lot when I have a lot of plugins open. I didn't have that issue with Pro Tools 11.
That happens both with Windows 8.1 and Windows 7. I have also tried a different gfx card on my PC to make sure this is not a GPU problem. What have they changed in the Pro Tools 12 ??? Anybody else experiencing this?? Here you can see an example of this problem. https://www.youtube.com/watch?v=sLFQ91vb2NQ |
Re: Pro Tools 12 and slow Graphics
Hello again.
Well, with stock plugins everything is cool, but I don't use them much anyway, so I am not sure. I use mainly Slate Digital plugins. The plugin that seems to be the heavier is TrackSpacer from WaveArts. I already sent them an email, and their answer was: That's really weird. Honestly, I don't think it's a TrackSpacer issue because: 1. We're not doing anything other than the normal on the graphic level. 2. Nobody else has reported this issue. And here is the Sandra report: SiSoftware Sandra ID Host Name : ProTools11 Workgroup : WORKGROUP Computer Model : MSI MS-7522 High-End Desktop Serial Number : To Be Fille*********** Chassis : MSI Desktop Mainboard : MSI X58 Pro-E (MS-7522) Serial Number : To be fille*********** BIOS : AMI (OEM) V8.15 03/19/2011 Total Memory : 12GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C 8T 2.67GHz/3GHz, 2.14GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1366 Chipset Memory Controller : MSI X58 I/O Hub 2x 2.41GHz (4.82GHz) Memory Controller : Intel Core Desktop (Bloomfield) UnCore 2x 2.41GHz (4.82GHz), 3x 4GB DIMM DDR3 1.07GHz 192-bit Memory Module(s) Memory Module : A-Data DDR3 1333 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : A-Data DDR3 1333 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : A-Data DDR3 1333 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : A-Data DDR3 1333 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : A-Data DDR3 1333 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : A-Data DDR3 1333 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Video System Monitor/Panel : Dell Computer DELL U2713HM (2560x1440, 27.2") Monitor/Panel : Philips 231E (1920x1080, 23.1") Video Adapter : NVIDIA GeForce GTS 250 (16CU 128SP SM4.0 1.51GHz, 1GB DDR3 1.8GHz 256-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTS 250 (16CU 128SP SM4.0 1.51GHz, 1GB DDR3 1.8GHz 256-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GTS 250 (128SP 16C 1.51GHz, 1GB DDR3 1.8GHz 256-bit) Compute Shader Processor : NVIDIA GeForce GTS 250 (128SP 16C 1.51GHz, 1GB DDR3 1.8GHz 256-bit) CUDA GP Processor : NVIDIA GeForce GTS 250 (128SP 16C 1.51GHz, 1GB DDR3 1.8GHz 256-bit) Storage Devices KINGSTON SV300S37A240G (240GB, SATA600, SSD) : 224GB (C:) INTENSO (128GB, SATA600, 2.5", SSD) : 119GB (E:) WDC WD1003FBYX-01Y7B1 (1TB, SATA300, 3.5", 7200rpm) : 932GB (D:) KINGSTON SV300S37A120G (120GB, SATA600, SSD) : 112GB (K:) WDC WD64 01AALS-00L3B2 (640.1GB, FireWire/1394) : 596GB (H:) HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-RW, CD-RW) : N/A (F:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (G:) Logical Storage Devices Win8 (C:) : 224GB (NTFS) @ KINGSTON SV300S37A240G (240GB, SATA600, SSD) System Reserved : 100MB (NTFS) SOUNDBANKS (D:) : 932GB (NTFS) @ WDC WD1003FBYX-01Y7B1 (1TB, SATA300, 3.5", 7200rpm) Snow Leopard (K:) : 111GB (HFSJ) @ KINGSTON SV300S37A120G (120GB, SATA600, SSD) NTFS2 (H:) : 596GB (NTFS) @ WDC WD64 01AALS-00L3B2 (640.1GB, FireWire/1394) Win7 (E:) : 119GB (NTFS) @ INTENSO (128GB, SATA600, 2.5", SSD) Optical Drive (F:) : N/A @ HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-RW, CD-RW) Optical Drive (G:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : MSI LPC Interface Controller LPC Legacy Controller 1 : Fintek F71882FG/F71883FG Disk Controller : MSI 6 port SATA AHCI Controller Disk Controller : MSI JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : MSI USB UHCI Controller #4 USB Controller 2 : MSI USB UHCI Controller #5 USB Controller 3 : MSI USB UHCI Controller #6 USB Controller 4 : MSI USB EHCI Controller #2 USB Controller 5 : MSI USB UHCI Controller #1 USB Controller 6 : MSI USB UHCI Controller #2 USB Controller 7 : MSI USB UHCI Controller #3 USB Controller 8 : MSI USB EHCI Controller #1 FireWire/1394 Controller 1 : MSI IEEE 1394 Host Controller FireWire/1394 Controller 2 : Unibrain FireBoard Blue SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Adobe PDF Converter (4000x4000, Colour) Printer : EPSON L800 Series (720x720, USB, Colour) Peripherals Media Player : INTENSO (119.14GB) Media Player : KINGSTON SV300S37A120G (111.47GB) Media Player : WDC WD1003FBYX-01Y7B1 (931.51GB) Media Player : WDC WD64 01AALS-00L3B2 (596.17GB) Network Services Network Adapter : Inventec PCIe GBE Family Controller (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows 8.1 Professional 6.03.9600 Platform Compliance : x64 Windows Experience Index Current System : 6.7 |
Hi
Here is another thread with the same issue as your utube video shows, in the first post in this thread http://duc.avid.com/showthread.php?t...+graphics+PT12 you can see the exact same thing so read thru that and see if you can extract some useful info for your problem. Best of Luck |
Thank you so much, I will check it right away!
I´m having the same problem but with OSX 10.11.3 and Pro Tools 12.5.2
Very sluggish graphic behaviour - even with AVID´s own plugins like Pro Limiter or Pro Multiband Limiter. :confused::( |
Or wait a week until Sierra is approved. Many are reporting that Sierra fixes it. Of course try it on a back up copy of your install to be smart. |
Just wait for Sierra to be approved, or go ahead and install it.
It fixed the problem. Don't forget to backup. Fixed my Pro Tools problem, but my M-Audio hardware no longer supported. So.........Spend thousands on new interface or........deal with video lag. |
I'll wait for fix another. |
