Avid Pro Audio Community (https://duc.avid.com/index.php)
-   003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) (https://duc.avid.com/forumdisplay.php?f=15)
-   -   Can't record to IOMega 500G FW800 Drive (https://duc.avid.com/showthread.php?t=248301)
pre911mindset 06-17-2009 08:59 PM
I get error -9131 immediately after starting to record audio to this IOMega UltraMax drive. I know this is a common error but I think I have checked for the common causes of this problem and none seem to apply to me. Please point it out if I have missed something.
I have been able to record on this same model in the past. I can play audio, midi, instrument tracks from this drive.
This drive from what I understand uses Oxford 811E chipset. I know that 911 is recommended but I'm not sure if that only applies to FW400 drives.
Here are the things I've checked:
1) the volume is partitioned for MacOS Extended Case-sensitive Journaled.
2) I checked in the Windows/workspace area and both A and V (audio and video) for the target drive are set for 'R' which again I think is correct.
3) This is a FW external IOmega 500G hard drive with FW800. There is only a single partition on the drive.
4) time machine is off.
Vital stats:
Macbook pro silver unibody 12/2008 (Intel core duo 2.4Ghz 2G Ram)
MacOS 10.5.7
LE8
MBox Mini (USB)
FW800 hard drive (for PT audio) and USB HD (for backups, disabled).
Thank you DUC community!
DigiTechSupt 06-18-2009 10:11 AM
Re: Can't record to IOMega 500G FW800 Drive
Case-sensitive formatting is not supported by Pro Tools. You'll need to reformat it without the case-sensitive option.
pre911mindset 06-18-2009 04:57 PM
Thank you! I don't mind reformatting the drive but I didn't want to do it and then just be faced with the same problem. The previous drive must have been formatted differently.
Craig F 06-18-2009 05:29 PM
most pre-formatted drive come FAT32
