Rig Settings
I am having a problem with one of my rigs.
I have a modulation effect set up in my rig, but I want it bypassed as default. I don't won't to have to remove it and add it back to the rig. All the other effects seem to let me bypass them and once I save the preset it is remembered. What happens is that I set modulation to bypass and save the rig preset. Then when I select the preset from the ground control pedal it reverts to the chorus setting. In other words chorus is on not bypassed. I want to leave the chorus in the rig for potential future use. Any ideas. |
Re: Rig Settings
What happens when you select the preset using the preset knob on the 11R?
If the mod block stays off when selecting that way, then the Ground Control must be sending an extra message when selecting that preset. |
Re: Rig Settings
I will check and post back.
