How do I authorize?
Well, I just DL'ed the update to PT LE 7, with my ilok in there, and I can't seem to authorize the thing. I get a server error message, and it says to manually activate it, but I don't know how.
It's probably real simple...but can anyone help? |
Re: How do I authorize?
I've got the same problem. No help so far.....
PTLE doesn't authorize with the ilok. You should have received a serial code via email when you purchased the upgrade, if you did it thru the digistore. You should contact DigiCS on Monday if you didn't get a serial code with your purchase.
