PT LE 8 Activation
Hi
I've sadly had to reinstall pt 8, and when I had to enter my activation code, if got the error, that it has allready been used (which is correct). But I cant find the code in my history, downloaded products etc. Hope someone can help me |
Re: PT LE 8 Activation
Isnt there anyone from AVID who can help... ?
i cant find an email to mail to on the digidesign.com webpage. |
This is odd. I have reinstalled 8 and used the same code several times. Is it the correct code? The one that starts with "DIGI0800........."
Activation only occurs once when registering a product. Pro Tools 8 uses an authorization code which should be on the inside front cover of the Getting Started manual or on the envelope of the DVD if you own an Eleven Rack.
When I then wanted to install pt8 it askes for the authorization code, but I only have the activation code. Can I mail you the activation code, so you can find me the authorization code ? |
