PANASONIC D5 layback?
Hello all! Has any one had to lay back to a PANASONIC HD3700 D5 deck yet? If so what did you use for deck, machine control, and track arm config did you use?
thanks in advance kidsound |
Re: PANASONIC D5 layback?
We use them here all the time. Our engineer made a custom track arming profile in machine control because none of the existing profiles work with the 3700. This is a new option in the version we got when upgraded to HD3. Before that I did the edit on the machine and let pro tools chase. I hope that helps.
The most reliable setup for D-5 that I've found is the AJ-D350 (D-3) node for the 9-pin control.
Hope this helps. |
