Can someone please help me?
This seems like it should be real easy...but I guess it's not.
I have a pair of Audio Technica studio headphones. They use the larger plug like 1/8th I think. When I plug them into my Echo Mia Midi, OR use an adapter to go into my sound card I can only hear one channel. Is there a way to fix this? Please help this is killing me. |
Re: Can someone please help me?
If you plug the headphones into two different units and you get only one side, perhaps the headphones or the headphone cable is defective. Do the headphones work on any other unit?
Yes they work in amps etc... Jus not in the mia midi. I only get the left channel
Also... If I am building a new computer and have this card with monitors hooked into it do I need another sound card?
I'm not familiar with the MIA MIDI but the spec I just looked at doesn't show a headphone output...
When did the headphone stop working on the MIA MIDI? Does the headphone 1/4" jack work on the 002 with your headphones? |
Yes it does but I wanted to use the headphones outside of PT also. IS there a way to play through the digi without having pt open? Like when Im using FL Studio for instance.
* Analogue inputs: two, balanced/unbalanced, nominal level +4dBu, maximum level +18dBu. * Analogue outputs: two, balanced/unbalanced, nominal level +4dBu, maximum level +18dBu. I don't see a headphone jack. I have looked at several pages of specs for the MIA MIDI and NONE show a headphone jack. A 1/4" jack can be just a mono audio out, not designed for a headphone. If you are using one of the 1/4" analog mono outputs for your headphone, you will hear that on only one ear. The 002 rack will not work without the software. The 002 mixer will work standalone. |
Damn so the headphones are useless outside of digi 001... that sux... oh well thanks.
