Audio out of sync within group when using playlists
Hi guys,
I've had a strange issue just crop up and not sure what's going on. Recently I recorded some drums (16 mics in total) - something I've done many times before but never had this issue happen. For each take, I created a new playlist. They are all in order and I've made notes on each one. When I go to create a new comp of the takes, this is where the issues seem to appear. So, I create a new playlist and then switch to Playlist view. I select what I want from take 4 and click the up arrow to send it to the top of the playlist. For some reason, this makes 4 of the tracks out of sync - it brings the overheads and room mics earlier than the other tracks. However, when I go to the playlist of take 4, the audio is fine; flipping between the two (the take 4 playlist and the same take promoted to the top of the comp), I literally see the tracks move! Also, they are in a different colour. Any idea what could be causing this? I recorded 4 songs that day and everything else seems fine with the others. Thanks in advance for any light you can shed! James |
Re: Audio out of sync within group when using playlists
This might be a bug. Can you do a copy from the playlists to the mains without this error? Command-c on playlists on selection, move up to mains and command-v.
Aha. Interestingly, that seems to work ok. For some reason, the tracks that were in question (overheads and room mics) still display in a different colour, but they don't appear to be moved this time and play in sync. Do you think it could be a glitch in the session itself, seeing as it doesn't seem to be causing a problem with the other 3 sessions? FYI, this was song number 3 and I was importing session data from the previous session each time I moved onto the next song. Just to make sure all of my channel inputs and headphone outputs etc remained consistent. |
