I/O setup crash when Artist controllers connected.
Lots of problems with stability with Artist controllers.
It´s all fine when everything is setup and patched but the crashes starts when you duplicate tracks, hide/show tracks and changes things in I/O or output routing. I have done everything with optimizing and computer is only used for Protools, fresh install on clean disc. Not even connected to internet. Problems starts as soon as I connect artist gear, to bad cause the features of the artist controllers are stunning. I hope this will be dealt with in the upcoming eucon which seems to be in beta. HD3 accel PT10HD 10.3.3. Mac pro osx 10.6.8. HD madi HD omni Yamaha DM2000 (3 channels oh HUI) Artist mix and control (latest eucontrol version) |
Trashing all PT and eucon prefs + repair permissions again seems to have improved stability a bit, fingers crossed.
This is a totally new fresh clean install so it seems a bit strange you have to do this already. The EQ page not always showing bug remains. |
Re: I/O setup crash when Artist controllers connected.
Hi Audioartist,
I´ve been having very similar crashes and was wondering if you managed to solve it. In my case, PT will randomly crash, but only if eucon with my Artist Mix is ON. Thanks! |
Everything works perfectly once the session is settled with all plugins, routing etc and as long as I leave everything as it is and just mix. The EQ page bug was fixed in 3.0 though. |
