SSL Native version 6 users, can you check something?
Ive just moved to the new version 6 after using the previous versions for many years and found a few things different on my PT10 mountain lion system. would like to know if other have these small issues... Does the ADC not work on drumstrip when in bypass? as soon as i bypass the drums all go out of time/phase/alignment as the ADC inst working when the plug is bypassed. No control surface support on any plugs? is this on all OS? completely not implemented? or just me on ML? Really miss the modifier key option on X-EQ to control the Q setting when adjusting the EQ on the graph. guess they just missed this one or didn't want to implement it this time. Chris |
Re: SSL Native version 6 users, can you check something?
Chris, I'll try to check these out for you. It may be a bit before I can get to it though.
I'm on Windows.
ADC works correctly when bypass on Drumstrip. I don't know what was the modifier key in the previous version of X-eq, I assume it is something similar to Waves R-eq, if so I can't find it either. |
Hi, Thanks, SSL have confirmed the ADC issue with drumstrip and have said they will mention the modifier key and control surface support to the development team. Chris Quote:
Hi, Thanks interesting to know its ok on windows. The modifier key could be used to adjust the Q shape. so up/down volume. left/right EQ and hold modifier key and adjust Q shape. was a great feature as you didn't have to let go of the EQ node to do everything. Chris |
For ADC, have You tried to "unable the plugin" completely for a while?
