Eucontrol v3.6.1 Now Avialable
1 Attachment(s)
Avid is pleased to announce the release of EuControl/Workstation software version 3.6.1 for the S3, Dock, Pro Tools|Control, and Artist Series. Log in to your Avid Account (for S3, Dock, and Pro Tools | Control) or My Artist portal to download the new software.
All EuControl Devices / EuControl Software • Over 10 conditions which previously could crash EuControl no longer do so. • It could be difficult for some plug-in knobs to reach their maximum and minimum values • Resetting Send level via Opt (Mac)/Alt (Windows)+touching a knob would reset it to –Inf/off instead of 0/unity • Navigating to Send/bus pan by pressing a Send knob could reset/clear Send level • EQ 3 Mid band control would not always switch to Q when Sel was pressed • It was possible for Wheel Modes and other functions to not be able to be assigned to Soft Keys on Mac • The EuControl Soft Key Editor now stays focused on the currently locked-to Application • The Workstation tab now uses a checkmark instead of an X Pro Tools | Control • Changing Automation mode via "Do to Sel" required two presses of the desired Automation • mode button • Mixer view would reset to the first 8 tracks when toggling between applications Pro Tools | Dock • The ALT switch sometimes needed convincing before allowing you to enter Preview mode Pro Tools | S3 • The Audio Control encoders (9–16) could exhibit delayed response when adjusting built-in I/O Note: Requires new S3 firmware provided in EuControl 3.6.1. Artist Series • Artist Transport: It was possible for the Soft Key to Restore Previously Shown Tracks to stop working Note: This fix requires Pro Tools 12.8 or higher. • Artist Transport: Several Shift layer Soft Keys on the numeric keypad that required a Wheel mode no longer worked Please note the following: Make sure control surface firmware is up to date after installing EuControl 3.6.1 A new version of Pro Tools | Control (v3.6.1) is available on the Apple App Store |
Re: Eucontrol v3.6.1 Now Avialable
can you tell me what is the the right software to run the Artist Mix with PT's 10 so I can see if I have the right program installed ..thanks
ok thanks i'll see if I can get it to work:confused:
I have Eucon in the computer but if I go to settings there is nothing listed under work surface
got it all working ...somehow Eucon got turn off in PT's was not enabled.But I downloaded the new V3.61 and firmware update changed the oil in the Artist Mix and all is good thanks for the help
