Digimax vs. digital mixer?
Hi everybody,
I currently have a Digi 001 with a Digimax 8 ch mic pre. The pre's for the Digimax are decent enough for my purposes and also give me 8 more channels of input and has worked great for me in tracking in the past. My set up also includes some gates and compressors from Behringer a 2442 16 channel Behringer UB board, BBE, and a Yamaha 32 channel dual band EQ. I mainly use the board for rehearsing with my band and as a control room section for my monitors and headphone mixes (the Digi 001 has a minimum 128ms latency issue). I was thinking of buying a Mackie HUI for a control surface, but then I thought maybe a digital mixer would be in order and then I could sell all my outboard gear. The only problem I am having is there are no comparisons to the Digimax pres and the pres on the Tascam and Yamaha digital boards. I like the idea of a digital mixer as it would work great for rehearsal and port to recording much easier than running everything from scratch for each to avoid latency issues when rehearsing. I have spoken with Presonus and they say that the pres in the Digimax are class A mic pres and I want to make sure if I do this that I can get the same quality pres in a digital mixer with HUI emulation for pro tools control, any ideas and has anyone else ever faced this same dilemma? Thanks for the help. |
Re: Digimax vs. digital mixer?
The Tascam DM24 and Yamaha 01V/96 will likely sound as good as the Digimax. The earlier digital boards would be a step backwards as the pres and converters have gotten much better in the last year or so.
The 01v96 was sent from god. You'll love the way it sounds and works as a control surface.
How do I get it to run as a control surface?
