AS11 issues
Hi guys I'm having some trouble here at work. We've just started packaging our productions in AS11 format with the audio to R128.
The mix I made for a show came back with this message: Measured Value (peak level) across stream duration: -6.2dB. It was below tested value: -1.0dB Any idea what this means? as the measurement of the audio file is -23 overall. Thanks |
Re: AS11 issues
Hi Gafyn,
-23 is the integrated value, the overall loudness of the program. -6.2 is the true peak value, which is below the maximum of -1.0 that is accepted. So your mix is compliant ! Best regards, |
