My Sandra - make suggestions. Have some popping.
***** Start of Report *****
-------------------------------------------------------------------------------- <<< Computer Overview >>> -------------------------------------------------------------------------------- < System > Model: Gigabyte Technology Co., Ltd. EP43-DS3L Workgroup: WORKGROUP Host Name: protools User: Eric Shults < Processor > Model: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz Speed: 2.5GHz Cores per Processor: 2 Unit(s) Threads per Core: 1 Unit(s) Type: Dual-Core Integrated Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing < System > Mainboard: Gigabyte Technology Co., Ltd. EP43-DS3L BIOS: Award Software International, Inc. F8 (09/22/ 2008) Bus(es): X-Bus PCI PCIe IMB USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes Total Memory: 3.25GB DIMM DDR2 < Chipset > Model: Giga-Byte P45/P43/G45/G43 DRAM Controller Front Side Bus Speed: 4x 294MHz (1.18GHz) Total Memory: 4GB DIMM DDR2 Memory Bus Speed: 2x 588MHz (1.18GHz) < Memory Module(s) > Memory Module: OCZ OCZ2VU8002G 2GB DIMM DDR2 PC2-6400U DDR2- 800 (5-6-6-18 3-24-6-3) Memory Module: OCZ OCZ2VU8002G 2GB DIMM DDR2 PC2-6400U DDR2- 800 (5-6-6-18 3-24-6-3) < Video System > Adapter: NVIDIA GeForce 8500 GT (16 SP 952MHz, 512MB DDR2 2x424MHz, PCIe 1.00 x16) Adapter: NVIDIA GeForce 8500 GT (16 SP 952MHz, 512MB DDR2 2x424MHz, PCIe 1.00 x16) < Storage Devices > Hitachi HDP725025GLA380 (250GB:233GB (C:) STECH Simple Drive 250GB (USB):233GB (F:) MITSUMI CR-48XATE (ATA33, CD-R:N/A (D:) LITE-ON DVDRW LDW-411S (ATA33,:N/A (E:) < Logical Storage Devices > Hard Disk (C:): 233GB (NTFS) @ Hitachi HDP725025GLA380 (250GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) Optical Drive (D:): N/A @ MITSUMI CR-48XATE (ATA33, CD-RW, 2MB Cache) Optical Drive (E:): N/A @ LITE-ON DVDRW LDW-411S (ATA33, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:): N/A SimpleDrive (F:): 233GB (NTFS) @ STECH Simple Drive 250GB (USB) < Peripherals > LPC Hub Controller 1: Giga-Byte LPC Interface Controller LPC Legacy Controller 1: ITE IT8718F Audio Device: Giga-Byte HD Audio Controller Serial Port(s): 1 Parallel Port(s): 1 Disk Controller: Giga-Byte 4 port SATA IDE Controller Disk Controller: Giga-Byte 2 port SATA IDE Controller Disk Controller: Giga-Byte JMB368 IDE Controller USB Controller 1: Giga-Byte USB UHCI Controller #4 USB Controller 2: Giga-Byte USB UHCI Controller #5 USB Controller 3: Giga-Byte USB UHCI Controller #6 USB Controller 4: Giga-Byte USB EHCI Controller #2 USB Controller 5: Giga-Byte USB UHCI Controller #1 USB Controller 6: Giga-Byte USB UHCI Controller #2 USB Controller 7: Giga-Byte USB UHCI Controller #3 USB Controller 8: Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1: Lucent/Agere Systems (Was: AT&T MicroElectronics) FW322/323 IEEE1394 OHCI FireWire Contro SMBus/i2c Controller 1: Intel 801xx/63xx SMBus < Network Services > Network Adapter: Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport Network Adapter: Belkin Wireless G USB Network Adapter #2 - Packet Scheduler Miniport (Ethernet, 36Mbps) Wireless Adapter 1: Belkin Wireless G USB Network Adapter #2 - Packet Scheduler Miniport (802.11g (ERP), 36Mbps) < Power Management > Mains (AC) Line Status: On-Line < Operating System > Windows System: Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance: x86 <<< Mainboard >>> -------------------------------------------------------------------------------- < System > Manufacturer: Gigabyte Technology Co., Ltd. Model: EP43-DS3L ID: 00000000-00000000-1F000000-5596D4D0 < System Chassis > Manufacturer: Gigabyte Technology Co., Ltd. Type: Desktop Can be locked: No < Mainboard > Manufacturer: Gigabyte Technology Co., Ltd. Multi-Processor (MP) Support: No MPS Version: 1.40 Model: EP43-DS3L Version: x.x BIOS: 09/22/2008-P43-ICH10-7A89PG0FC-00 < System Memory Controller > Location: Mainboard Error Correction Capability: None Number of Memory Slots: 4 Maximum Installable Memory: 4GB Bank0/1 - A0: DIMM 2GB/64 @ 800MHz Bank2/3 - A1: DIMM 2GB/64 @ 800MHz Bank4/5 - A2: Empty Bank6/7 - A3: Empty < Chipset > Model: Giga-Byte P45/P43/G45/G43 DRAM Controller OEM Device Name: Intel P45/P43/G45/G43 DRAM Controller Revision: A4 Bus: Intel AGTL+ Number of FSB Channels: 1 Front Side Bus Speed: 4x 294MHz (1.18GHz) Maximum FSB Speed: 4x 333MHz (1.33GHz) Width: 64-bit Crossfire Technology: Yes I/O Queue Depth: 12 request(s) Maximum Bus Bandwidth: 9.19GB/s Maximum Power: 24.00W < Features > ME - Management Engine: Yes AMT - Active Management Techno:Yes < Chipset 1 Hub Interface > Type: DMI (Direct Media Interface) Version: 1.00 Number of Ports: 4 In/Out Width: 4-bit / 4-bit Multiplier: 3x Speed: 1x 100MHz (100MHz) < Logical/Chipset Memory Banks > Bank 0: 1GB DIMM DDR2 2-6-6-18 3-24-10-7 2T Bank 1: 1GB DIMM DDR2 2-6-6-18 3-24-10-7 2T Bank 2: 1GB DIMM DDR2 2-6-6-18 3-24-10-7 2T Bank 3: 1GB DIMM DDR2 2-6-6-18 3-24-10-7 2T Maximum Installable Memory: 8GB Supported Memory Types: DIMM DDR2 DDR3 Channels: 1 Memory Bus Speed: 2x 588MHz (1.18GHz) Maximum Memory Speed: 2x 400MHz (800MHz) Multiplier: 2x Width: 64-bit FMA - Fast Memory Access Suppo:Yes Refresh Rate: 7.80µs Power Save Mode: No Fixed Hole Present: No Maximum Memory Bus Bandwidth: 9.19GB/s < APIC 1 > Version: 2.00 Multiplier: 1/2x Maximum Interrupts: 24 IRQ Handler Engaged: Yes Enhanced Support: Yes < Memory Module > Manufacturer: OCZ Model: OCZ2VU8002G Type: 2GB DIMM DDR2 Technology: 16x(128Mx8) Speed: PC2-6400U DDR2-800 Standard Timings: 5-6-6-18 3-24-6-3 Version: 1.02 Memory DC Line: 1.80V Timing @ 400MHz: 5-6-6-18 3-24-6-3 Timing @ 333MHz: 4-5-5-15 3-20-5-3 Timing @ 267MHz: 3-4-4-12 2-16-4-2 < Memory Module > Manufacturer: OCZ Model: OCZ2VU8002G Type: 2GB DIMM DDR2 Technology: 16x(128Mx8) Speed: PC2-6400U DDR2-800 Standard Timings: 5-6-6-18 3-24-6-3 Version: 1.02 Memory DC Line: 1.80V Timing @ 400MHz: 5-6-6-18 3-24-6-3 Timing @ 333MHz: 4-5-5-15 3-20-5-3 Timing @ 267MHz: 3-4-4-12 2-16-4-2 < Environment Monitor 1 > Model: ITE IT8718F LPC Version: 5.00 Mainboard Specific Support: No < Environment Monitor 2 > Model: Intel Core CPU [P1, C2, T100] Version: 23.06 Mainboard Specific Support: No < Environment Monitor 3 > Model: ITE ITE820X SMB Version: 0.18 Mainboard Specific Support: No < Temperature Sensor(s) > Board Temperature: 39.00°C CPU Temperature: 42.00°C td < Cooling Device(s) > Auto Fan Speed Control: No System Fan: 934rpm < Voltage Sensor(s) > CPU DC Line: 1.14V Aux DC Line: 1.89V +3.3V DC Line: 3.26V +5V DC Line: 5.03V +12V DC Line: 0.25V -5V DC Line: -8.48V Standby DC Line: 5.32V Battery DC Line: 3.09V < System Bus(es) on Hub 1 > Version: 2.30 System Bus 0: PCI System Bus 1: PCIe 2.00 x16 2.5Gbps System Bus 2: PCIe 1.00 x1 2.5Gbps System Bus 3: PCIe 1.00 x1 2.5Gbps System Bus 4: PCIe 1.00 x1 2.5Gbps System Bus 5: PCI66 < LPC Hub Controller 1 > Model: Giga-Byte LPC Interface Controller OEM Device Name: Intel LPC Interface Controller Revision: A1 ACPI Power Management Enabled: Yes Advanced TCO Mode Support: Yes Advanced TCO Mode Enabled: No High Precision Timer Enabled: Yes Number of Precision Timers: 4 System Timer: 14.32MHz Delayed Transaction Enabled: Yes < LPC Legacy Controller 1 > Type: ITE IT8718F Version: 0.18 Number of Enabled Devices: 6 < Disk Controller > Model: Giga-Byte 4 port SATA IDE Controller OEM Device Name: Intel 4 port SATA IDE Controller Interface: SATA Revision: A1 Maximum SATA Mode: G2 / SATA300 RAID Support: Yes RAID Enabled: No Channels: 4 In Use Channels: 1 Port: G1 / SATA150 < Disk Controller > Model: Giga-Byte 2 port SATA IDE Controller OEM Device Name: Intel 2 port SATA IDE Controller Interface: SATA Revision: A1 Maximum SATA Mode: G2 / SATA300 RAID Support: Yes RAID Enabled: No Channels: 2 < Disk Controller > Model: Giga-Byte JMB368 IDE Controller OEM Device Name: Jmicron JMB368 IDE Controller Interface: ATA Revision: A1 Channels: 4 < Audio Device > Model: Giga-Byte HD Audio Controller OEM Device Name: Intel HD Audio Controller Revision: A1 Type: HD (High-Definition) Audio Version: 1.00 Number of In / Out / Bi-Direct:4 / 4 / 0 Number of Serial Data Streams: 1 < USB Controller 1 > Model: Giga-Byte USB UHCI Controller #4 OEM Device Name: Intel USB UHCI Controller #4 Revision: A1 Version: 1.10 Interface: UHCI Channels: 2 Speed: 48MHz Supported Speed(s): Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled: No < USB Controller 2 > Model: Giga-Byte USB UHCI Controller #5 OEM Device Name: Intel USB UHCI Controller #5 Revision: A1 Version: 1.10 Interface: UHCI Channels: 2 Speed: 48MHz Supported Speed(s): Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled: No < USB Controller 3 > Model: Giga-Byte USB UHCI Controller #6 OEM Device Name: Intel USB UHCI Controller #6 Revision: A1 Version: 1.10 Interface: UHCI Channels: 2 Speed: 48MHz Supported Speed(s): Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled: No < USB Controller 4 > Model: Giga-Byte USB EHCI Controller #2 OEM Device Name: Intel USB EHCI Controller #2 Revision: A1 Version: 2.00 Specification: 1.00 Interface: EHCI Channels: 6 Companion Controllers: 3 Supported Speed(s): Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support: 64-bit Legacy Emulation Enabled: No < USB Controller 5 > Model: Giga-Byte USB UHCI Controller #1 OEM Device Name: Intel USB UHCI Controller #1 Revision: A1 Version: 1.10 Interface: UHCI Channels: 2 Speed: 48MHz Supported Speed(s): Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled: No < USB Controller 6 > Model: Giga-Byte USB UHCI Controller #2 OEM Device Name: Intel USB UHCI Controller #2 Revision: A1 Version: 1.10 Interface: UHCI Channels: 2 Speed: 48MHz Supported Speed(s): Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled: No < USB Controller 7 > Model: Giga-Byte USB UHCI Controller #3 OEM Device Name: Intel USB UHCI Controller #3 Revision: A1 Version: 1.10 Interface: UHCI Channels: 2 Speed: 48MHz Supported Speed(s): Low (1.5Mbps) Full (12Mbps) Legacy Emulation Enabled: No < USB Controller 8 > Model: Giga-Byte USB EHCI Controller #1 OEM Device Name: Intel USB EHCI Controller #1 Revision: A1 Version: 2.00 Specification: 1.00 Interface: EHCI Channels: 6 Companion Controllers: 3 Supported Speed(s): Low (1.5Mbps) Full (12Mbps) High (480Mbps) Addressing Support: 64-bit Legacy Emulation Enabled: No < FireWire/1394 Controller 1 > Model: Lucent/Agere Systems (Was: AT&T MicroElectronics) FW322/323 IEEE1394 OHCI FireWire Contro OEM Device Name: Lucent/Agere Systems (Was: AT&T MicroElectronics) FW322/323 IEEE1394 OHCI FireWire Contro Revision: G2 Version: 1.00 Interface: OHCI Enhanced Support: No Channels: 64 Speed: 400MHz < SMBus/i2c Controller 1 > Model: Intel 801xx/63xx SMBus Specification: 2.00 Advanced TCO Mode Enabled: Yes Slave Device Enabled: Yes PEC Support: Yes Speed: 100kHz < Expansion Slot(s) > PCI: PCI 32-bit +5V +3.3V PME i2c/SMBus Full- Length Used PCI (1h): PCI 32-bit +5V +3.3V PME i2c/SMBus Full- Length Used < Port Connector(s) > PRIMARY IDE: ATA SECONDARY IDE: ATA FDD: 8251 FIFO / Floppy Disk COM1: Serial Port 16450 / 9 Pin Dual Inline / DB-9 pin male COM2: Serial Port 16450 / 9 Pin Dual Inline / DB-9 pin male LPT1: Parallel Port ECP/EPP / DB-25 pin female / DB- 25 pin female Keyboard: Keyboard / PS/2 PS/2 Mouse - Detected: Mouse / PS/2 / PS/2 USB: USB / USB USB: USB / USB < Performance Tips > Notice 224: SMBIOS/DMI information may be inaccurate. Tip 2511: Some memory slots are free so the memory can be easily upgraded. Warning 2523: Memory bus speed exceeds memory rated speed. Reduce memory bus speed. Warning 2542: Memory bus speed exceeds Chipset rated speed. Reduce FSB/memory multiplier. Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip |
