Find you audio file
When you in a project editing, resizing an audio file for example and lets say this audio file is " audio 1" then you obtain another file called "audio 1-01" or something like that you know....
Question: 1/ Can we find those 2 files thrue spotlight if they are on the disk of course ? Coz i dont know why but i dont always find them, whereas im sure they are on this disk... |
Re: Find you audio file
If by 'resizing' you mean trimming, then this creates a new clip in Pro Tools but does not create a new audio file - it's just a pointer to the audio in the original file. If you process the file in any way (audiosuite, render elastic, etc) then you will get a new file. You can always view filename in the clip bin to see if it's a different parent file.
If all your disks are spotlight-enabled, then you should be able to find them through spotlight. That said, using a dedicated find utility such as Easyfind or Findanyfile may be a better way to go. You can also always view and reveal file locations from the session browser window. best, rich |
so IF Make a loop from an audio file, i will not find it thrue spotlight because PT will not create another file right ? I will just be able to find the root file right ??? |
