Avid Pro Audio Community (http://duc.avid.com/index.php)
-   Post - Surround - Video (http://duc.avid.com/forumdisplay.php?f=8)
-   -   5.1 EQ & Comp (http://duc.avid.com/showthread.php?t=350646)
fretfingers 02-03-2014 04:37 PM
5.1 EQ & Comp
Hi Guys,
Looking for 5.1 EQ and Compression recommendations. These would be work-horses mostly for stems and master bus.
I've been using multi-mono versions of Waves REQ6 and SSL Comp but using too many voices that way. Looking for something designed with 5.1 in mind.
So far I've been looking into DMG Audio Equilibrium and The Avid Pro Compressor.
Any suggestions?
dr sound 02-03-2014 05:58 PM
Re: 5.1 EQ & Comp
I think your choices should be:
Avid Pro Compressor
Avid Pro Limiter
Fab Filter Pro L Limiter
Those will all work extremely well for you.
Peter Cole 02-03-2014 06:26 PM
Re: 5.1 EQ & Comp
Avid Pro Compressor
Avid Pro Limiter
I believe the FabFilter Pro L is stereo and multi mono only.
tamasdragon 02-04-2014 04:21 AM
Re: 5.1 EQ & Comp
Let me add Fabfilter Pro Q to that list. Spectacular eq.
MIKEROPHONICS 02-04-2014 11:11 AM
Re: 5.1 EQ & Comp
I am quite liking this too - demoing at mo
Works nicely on the Raven
fretfingers 02-04-2014 01:16 PM
Re: 5.1 EQ & Comp
I love fabfilter… but I didn't think it did surround either… can anyone confirm or deny true surround (as opposed to multi-mono)
Thanks!
mgoorevich 02-04-2014 01:37 PM
Re: 5.1 EQ & Comp
AFAIK the only 5.1 EQ is a part of the Avid Channel Strip.
fretfingers 02-04-2014 02:06 PM
Re: 5.1 EQ & Comp
DMG does surround.
Craig F 02-04-2014 03:23 PM
Re: 5.1 EQ & Comp
There is no difference in voice usage between a multi-mono and a muti-channel plug-in
Or are saying that you need a AAX DSP plugs do to Waves only doing AAX Native?
The Cargo Cult 02-04-2014 04:47 PM
Re: 5.1 EQ & Comp
multi-mono is a PITA when reconforming
