Avid Pro Audio Community (http://duc.avid.com/index.php)
-   003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) (http://duc.avid.com/forumdisplay.php?f=17)
-   -   hard drive partitioning questions (http://duc.avid.com/showthread.php?t=64048)
spencer_davey 05-09-2002 03:00 PM
Re: hard drive partitioning questions
ps.
sorry if this is confusing, I'm running on zero hours of sleep right now and about two the night before that.
thanks
spencer
Mark_Knecht 05-09-2002 03:03 PM
Spencer,
Try this combination:
IDE-1: System drive is master, CD-ROM is slave
IDE-2: Audio drive is master, CDRW is slave
Cheers,
Mark
Originally posted by spencer_davey:
ps.
thanks
spencer
<font size="2" face="Verdana, Arial">
spencer_davey 05-10-2002 12:39 AM
Hi all,
A couple of questions:
1. If I am running 2 hard drives, a cd burner and cd rom in my pcu do want the hard drive with the OS and pro tools on it to be the master with the cd burner set to cable select connected to the #1 IDE slot and the dedicated audio drive with the cd rom set to cable to select connected to the #2 IDE slot, (I only have 2 ide connections) or a different configuration?
2. How do I want to assign audio storage on my drives if I am using WaveLab also? Should my dedicated audio drive only be allocated for PT and keep my wavelab temp files on the HD with the OS or can I put the wavelab temp files on the audio drive with the PT session files? (I don't think it should matter since I am not using both programs at once, but I'm just making sure...)
thanks for the help
spencer
