Re: ICON D ? Is this the new controller?
Shan |
It sures will boost competitors appetite; now if we were just not so many Protools users, they certainly woudn't have even tried that. But maybe the 60k annoucement is a test ?? |
I would like to have some (I think) easy to program features that will make pro tools even better (even pro):
-Auto match time (same name in NEVE-glide time in SSL) should be variable in automation enable window (you don't have to go to preferences and stop the playback. This parameter is very easy to acces in NEVE an SSL consoles and is very usefull), should have all the posible units (as you work in grid or nudge. It "will be very musical" if we have all the units, normaly in frames in big consoles and in ms in Pro tools) and should have longer times available (from 0 to a few seconds... bars... 1/4 notes... will be perfect) -There should be a software option to switch off the motor-faders while checking a mix. -In auto touch-trim mode faders should remain in 0dB position to make trim easier and go back to 0dB when you release the fader (acording to automatch time) like some big digital mixers, is quite carzy if you have to stop a fader in a very fast passage move just a fraction of dB and release it while is jumping to its old position. This option will make my anterior wish unnecesary, just switch all the faders to this mode -There should be a trim zoom mode to work with +/- 3 dB resolution in +/- 6 dB fader region length to improve vocal or instruments rides (I know +12 faders are coming...) This features will make easier and nicer to mix in pro tools I have some ideas for ICON D... But probably is too late... For example: What about have 8 faders asignable to any channels in the central position? (the keyboard should be over the faders...) What about a mouse or a wacom tablet option for the track ball? (chose what you prefer!!!) Neve style Mix pass tree... sounds nice Please implement new functions in the control 24 function keys. If ICOND is such an expensive... I will stay whit control 24 and the audient 5.1 control room controler. |
I was looking for an improved Pro-Control and not at $60,000.......Oh,well
I too was truly disappointed in seeing what this turned out to be...
I have a 24 fader PC in a mix room and was wanting to upgrade the analog console in our main room. We record to Radar and PTHD. Have been waiting for this and now I guess I might just proceed with shopping for a Neve or API for less money. This was not what many of us were expecting and for this kind of money? Geez! |
JLC...
most of what you requested as PT features already exist !!! -Auto match time (same name in NEVE-glide time in SSL) should be variable in yes you have to stop playback but thats not a big deal. You could use quick keys to automatically mark a point in time during playback, open prefs, change the match time, and resume playback. You could have a few diferrent times setup too. I have an SSL j here too and its is much faster in ProTools to stop playback and change the match time than it is to pick up your stylus, navigate to the match window, pull the keyboard drawer out and type in the new time. Even if you dont stop playback it still isnt ultra quick. -There should be a software option to switch off the motor-faders while checking a mix. Automation prefs: you can turn the motors off "Faders move during playback" -In auto touch-trim mode faders should remain in 0dB position to make trim easier and go back to 0dB use auto write:trim mode and this will do exactly what you want. a very cool feature There should be a trim zoom mode to work with +/- 3 dB resolution in +/- 6 dB fader region not exactly what you want but iff you hold the apple key down and use a mouse or trackball the faders and all auto parameters will move in a "fine" mode for those tiny adjustments hope all this helps !!!! |
Didn't Digi go out and ask people who work on large format consoles there needs and wants? Very odd?
how can you pan in surround with a rotary encoder? You mean using two rotary encoders (L/R, F/B)? that would kind of suck if you had to use two rotary encoders to pan in surround. What panner issues are there, you mentioned when digi resolves the panner issue? |
Some people have suggested that Digi should have put Mic Pre's on the desk...why do such a thing when they have a dedicated box with Pre's in it already? And when you put all the numbers together, the whole Digi system comes in WAY cheaper than the competition AND is the only one which includes the recording and editing of ProTools. You just can't please everybody now, can you? |
------ well that really depends on how well you can draw circles with an Etch-A-Sketch Martin |
