Opening a Kontakt Multi saved with 5.6.5 in 5.5.2
Kontakt 5.6.x is giving Pro Tools a lot of grief, crashes, CPU meter spikes. I have 17 multis I need to open in 5.5.2 the last known stable 64 bit AAX. I'm really hoping I don't have to go through and load them all one by one again. Thank you to anyone that can help!
Re: Opening a Kontakt Multi saved with 5.6.5 in 5.5.2
Is kontact inside vepro wrapper? Or as a protools instrument track?
If not inside vepro... Demo vepro6. Stick kontact in that. See if it helps. Sent from my SM-G935V using Tapatalk |
... it is not backwards compatible .. which is why i have still not updated K5 |
Just install K5.5.2 right over the top of K5.6.x. The only heartburn you may have is if you updated the Kontakt Factory library when K5.6.x came out. And even that is only if you use the Kontakt Factory library.
