Avid Pro Audio Community (http://duc.avid.com/index.php)
-   Pro Tools HDX & HD Native Systems (Mac) (http://duc.avid.com/forumdisplay.php?f=94)
-   -   HDX2 EB7 Chassis + External Hard Disk = Crash :( (http://duc.avid.com/showthread.php?t=369386)
Daniel Sasso 07-02-2015 07:39 AM
Hi, I´m having issues using HDX2 installed on EB7 Chassis and a external drive. It doesn´t matter if it is USB or a FireWire. Is someone having same issues?
PT10.3.10 HDX2, a blackmagic and a USB Card are installed also, but not on EB7.
DetroitT 07-06-2015 02:44 PM
Re: HDX2 EB7 Chassis + External Hard Disk = Crash :(
Does it work fine recording to your internal drives?
Have you used DigiTest to test cards and firmware while in the chassis?
Was this system ever working or are parts of it new to your system.
EB7's PCIe card slot-position?
Daniel Sasso 07-28-2015 05:56 AM
Sorry for long delay about this issue, very busy weeks... I tried everything... the only solution that appeared to work solid is installing HDX cards inside Mac and Blackmagic and USB 3.0 card in chassis. I´m still doing tests, but so far, I think I found a solution.
