Avid Pro Audio Community (http://duc.avid.com/index.php)
-   macOS (http://duc.avid.com/forumdisplay.php?f=92)
-   -   PT 12.4 LLM issue (http://duc.avid.com/showthread.php?t=379645)
Pedro perez 04-04-2016 10:27 PM
PT 12.4 LLM issue
So,select LLM and you are **** outta luck when it comes to monitoring through your interface of choice and thus to any custom headphone cue.this really reminds me why I abandoned pro tools back in 2005,why in the heck do they "deny"LLM other than to main LR at all?
Pedro perez 04-05-2016 02:32 PM
Re: PT 12.4 LLM issue
Anyone with a work around? Imac,clarett 8 PT12.4
mesaone 04-05-2016 03:02 PM
What's the issue? LLM is designed to let your sound card handle the input monitoring.
If LLM is messing with your workflow, turn it off.
Pedro perez 04-05-2016 03:57 PM
When I turn LLM on I see the signal but don hear it on my clarett 7-8 outs (headphone cue) but can hear it only after signal has been recorded.
Ps> I tried 64 sample buffer but got a bunch of clicks and pops. :(
mesaone 04-05-2016 04:07 PM
Seems to me that LLM is operating as intended, and you need to configure live input monitoring and cue routing from within the Focusrite Control app.
Pedro perez 04-05-2016 04:10 PM
I will try that this evening.if LLM doesn't mute audio anywere in the bussing system my apologies,it must be me,but I even tried all presets within focusrite app.
Pingafuego 04-14-2016 07:25 AM
check this thread:
http://duc.avid.com/showthread.php?t...put+monitoring
It´s about avid interfaces, but maybe it can help you!
Rich Breen 04-14-2016 08:29 AM
Please start with the PT ref manual:
"... certain Core Audio and ASIO audio interfaces that have a built-in mixer can use the Low Latency Monitoring option. Only tracks with inputs set to a physical output (not an internal mix bus) use Low Latency Monitoring. If your Core Audio or ASIO hardware does not have a built-in mixer, Low Latency Monitoring does not function. If you do enable Low Latency Monitoring with such hardware, monitoring will not available for record-enabled tracks in Pro Tools.
For all others systems, assign each track output to either Output 1 or Output 2 (mono), or both (stereo). Only tracks assigned to these outputs use Low Latency Monitoring."
