trim tool question
Protools question of the day. Why does the trim tool sometimes affect the entire track, and other times only affect the region the tool is over? This question applies to the edit window when an audio track is selected to read something other than waveform, such as volume, mute or pan.
Re: trim tool question
I'm pretty sure that's by design. If I use the trim tool on a blank area of a track with no clips or automation, it raises or lowers the value for the entire track, but if I select an area over a clip, it changes the values only for the clip.
The best way to make sure the whole track is affected evenly is to use the trim tool at the end of the track, beyond any clip or automation point. Anywhere else, you're likely to affect only part of the track, or to cause an unintentional angled line somewhere.
Apart from that, the rules are a bit obscure. You just have to watch carefully and see if it's doing what you want. |
Easiest way is to get used to using the multi tool (so you can select and then trim.) If there are breakpoints within the selection, it will affect the section between breakpoints. If there are no breakpoints, then new breakpoints will be created at the selection start/beginning and everything in between will move evenly. |
Make the track your editing in larger so you have more room to move the cursor before it changes. There is a setting that will enlarge the track you're in and make the other tracks smaller, but I'm not at PT right now and can't remember what it is.
