Save path for IO settings in Lion?
Simple question, but I can't find these things. Read that they were saved with the session, but no .pio files there.
Does this have anything to do with Lion hiding the Library folder? That's open and available but nothing there either. A bunch of .pio files come up in the Avid troubleshooting folder, but none that I've saved. Can someone clue me in? Thanks! MMS 2 GHz i7 16Gb RAM 10.7.5 PT 10.3.2 |
Re: Save path for IO settings in Lion?
Just in case someone else is having a brain fart, click "Import Settings", then "More Info" on one of the files you've saved. If you haven't created a new path, the default will be /Applications/Avid/Pro Tools/IO Settings.
Still don't understand why these don't show up in a search, but there you go. |
