AutoTune berserk after changing session start time
PT 7.4.2.
After doing some moderate tuning in graphic mode. I did a session start time change, maintaining region timecode position. I'm talking WACKED...weird, incorrectly pitched shifts...just bizarre. I had to go back to a previous save, record the tuned track and import it into a newer saved session. Anyone else? |
Re: AutoTune berserk after changing session start time
AT keeps track of the pitch changes from the top of the session.. by changing it, you affect AT's offset.
Did you also change the memory allocation setting inside AT to cover the longer timeline? Rail |
Once you use graphic mode in AT (or Waves Tune), you cannot make edits that change the timeline without having to redo your pitch corrections from that point in the timeline thru the end of the song. That' just the way it is.
