Avid Pro Audio Community (http://duc.avid.com/index.php)
-   003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) (http://duc.avid.com/forumdisplay.php?f=15)
-   -   Keyboard shortcuts for Powerbook Mac? (http://duc.avid.com/showthread.php?t=120977)
DESVED 11-14-2004 01:35 PM
Is there a place where you can find all the keyboard shortcuts when using a Powerbook laptop,
I can't find the "nudge" shortcut for example....
any help is welcome
thx
Rock_Artist 11-14-2004 02:46 PM
Re: Keyboard shortcuts for Powerbook Mac?
On both my Ex-iBook (waiting for the new one ) and my Centrino PC.
You should NUNLOCK the keys to get some keys to perform as Keypad.
Then you have the +/- of nudging.
They should be written on the keyboard in different color or size.
DESVED 11-14-2004 03:18 PM
I'll check this out tomorrow
thx for the tip
Avid 11-14-2004 04:20 PM
As mentioned...
On the current Powerbook G4, if you press the num lock/F6 key in the middle of your top row of keys. That locks in your right side of the keyoard to use the same as the number keypad in an extended keyboard.
Also...
If you only want to do it for a single instance, hold the fn key on the bottom left of your keyboard while pressing one of the number or +,-,*, /, = keys, the fn key modifies/enables the smaller characters on your keyboard on the right side, so they work the same as the number keypad.
I would assume it is the same or similar for iBook or earlier Powerbooks. I think it was the same on my now dead G3 Powerbook.
