In PT 7.0 meters are acting weird!!!!
Hey everyone!
I upgraded to PT 7,0. All is well, except one minor thing: When I open a session and start playing back the tracks the meters that have no volume increase or audio( flat waveform) show that there is signal being played... but it's irregular. Like if it was glitter. But when you solo that precise track there is no sound or noise present! (To be clear let's say the drums are playing on one track and the bass is silent on another, I still get signal from the meters from the bass track altough there is no signal or waveform playing.) It's like if the tracks that have audio playing are creating leakage in the track that are silent but without actual audio being played back. Basicaly I've got a metering problem... If I switch to pre-fader metering the problem get's solved. So I was wondering if someone has got the same problem. My specs: G4 Quicksilver Dual 1ghz processor (I know it's not supported...) 1 Gig of Memory 002Rack Behringer BCF2000 Thank You Mark |
Re: In PT 7.0 meters are acting weird!!!!
Yeah I've posted about this problem a couple of times but nobody else seems to have it!
It's very annoying cos it also "adds" to meter readings where there IS audio and makes it peak when it actually isn't peaking! I'm using PT 7 with OSX 10.4.3. (it happened in 10.4.2 too) n a Dual 1.8 G5 1st gen with 2.5 G RAM. What OS are you using Mark? Wes |
Mark & Wes, are you also getting this weird metering issue when there is no region on any given track and the meter(s) just flicker away? Also, does it seem to be worst when instantiating different type plug-ins (Digi's vs. any 3rd party) on that particular track?
Thanks... |
I've got the same problem and I kown another user with the same problem
p7.0 (of course), PIV win xp home. I'll try to run a session without plug-ins. |
I will make some notes next time it happens about what plug ins ive got going. Cheers, Wes |
I'm having the same problem. It only seems to happen when my Playback Engine is set to 2 Processors. Once I switch to 1 processor the problem goes away.
I'm on a G5 Dual-2.5. peace, dc |
We are aware of this and will be addressing it in an update to Pro Tools.
Yeah!!!!!
Digi to the rescue! Thanks! Mark |
PT 7.0 with Quicksilver???
Mark,
I read your post and saw that you're using PTLE 7 with a Quicksilver Mac and an 002r. How is it running? I have a Quicksilver dual GHz Mac and 002, but wondering if its safe to try PTLE 7 with this machine. Others have reported major file corruption problems, and I'm not sure I can afford to risk that. Can you describe your experiences with your set up, and what sort of files and plug ins you are using? thanks for your time, Dave Quote:
