Can't change my signature
I'm trying to edit my signature but it's impossible. In my profile there are a lot of pencils for changing my name my gear and everything it only misses at the signature tab. Can someone repair, please? Thanks. Mark |
Re: Can't change my signature
You're saying when you go to your user CP (control panel) and click on the hypelink on the left side of the page in the 'Your Control Panel' area and then in the 'Settings and Options' subsection and you click on 'My Signature' you can't edit your signature? If you do all that I wrote just to the right should be a fairly large section that at the top has a 'Preview' window that shows your current signature and just below that should be a window called 'Edit Signature' where you edit your signature. Below that when you're done there are two buttons - one to preview the edited signature and when to save the edited signature.
1 Attachment(s)
Thanks Jack,
but there's nothing you described… I've attached a screenshot. Mark |
1 Attachment(s)
I pressed edit signature on the left side in the user cp and get this and thats where you edit, not where you showed as it is the wrong section.
Thanks,
the user interface is a bit misleading. I didn't recognize I have to go to the "User CP" section… Mark |
Took a while to figure out whats what but now i have learned :-) Let us know if you need anything buddy Best Regards Christopher |
