Avid Artist Mix Setup - Ableton
I have the latest version of EUControl 3.2.2 and the latest firmware 1.5.4 and i'm finding it incredibly frustrating to setup the Artist Mix with Ableton.
I have gone to EUCon in OS X preferences and tried to drag and drop the Ableton App onto the center preferences box as described in the manuals but nothing!! No app will drop onto this area! Any ideas? What's the best way to get this thing running on a Ableton Live Yosemite Mac setup? |
Re: Avid Artist Mix Setup - Ableton
I don't have a solution, but I wish you luck. I have tried and failed to get my Artist controllers to work with Reason, which uses the same protocol as Live.
Eucon doesn't work with ableton. You'd have to use the HUI/Mackie emulation
As a workaround I added Ableton Live manually in the EuControl preferences file com.euphonix.EuConSystem.plist using the plist editor "Pref Setter". Add the identifier, name, path, midi ports, and protocol under the node "EuCon Applications".
All's working fine again. (If you have several versions of Live installed it's enough to add one of them.) https://unsee.cc/zenasimu/ |
hoeglund - would you be able to do a screenshot of your plist settings please as i've not edited these before. |
As hoeglund mentioned, edit com.euphonix.EuConSystem.plist, which lives in /Users/*yourusername*/Library/Preferences/.
If you are using Pref Setter, add an array to the EuCon Applications item (which will then automatically be named Item 1) and then add 5 keys, all of them strings: - App Identifier: "com.ableton.live" - App Name: "Live" - App Path: your path to ableton, something like "/Applications/Ableton Live 9 Suite.app" - MIDI Ports: "1-4" - Protocol: "MackieControl" Save the preferences on Pref Setter and restart your mac, you should be all set! Here's a screenshot of the Pref Setter screen: https://dl.dropboxusercontent.com/u/...prefsetter.png |
Hi Jorge - thanks for the info, unfortunately I can't see the attached image for some reason :-/ would you be able to upload it to somewhere, Dropbox etc. I've tried to edit via pref setter but I must have something wrong as the eucontrol preferences won't open now.
Updated the image URL, you should be able to see it now. Sorry about that.
Answer: prepare for frustration. Avid's support of Mackie Control Protocol is terrible.
http://duc.avid.com/showthread.php?t=354097 Quote:
