MBOX2PRO doesn\'t work with OSX 10.5.3/7.4.2p pre release
Is this really possible?
I have a MacBook 2.2 GHz Intel core duo and I was running 10.5.2 and PT 7.3.1 worked in that okay for me. Today I downloaded 7.4 with the music production toolkit that I have and upgraded to OSX 10.5.3 Now the 7.4.2p doesn't find the hardware, it claims it's "not connected"? How is this possible? |
Re: MBOX2PRO doesn\'t work with OSX 10.5.3/7.4.2p pre release
Did you do a clean uninstall of 7.3.1 before installing the 7.4.2PR? If not - please try that. Actually, you'll need to do a clean uninstall of both, then restart and reinstall just 7.4.2PR.
MIne is working perfectly....
did you install 10.5.3 from the combo updater? because that`s what i did... Hope that helps.. |
That actually did the trick. I just updated the OSX straight from Macs "update sofware" function.
This combo update did the trick and all works vey smoothly. Thank you:) |
