11r mutes randomly
I use 11r in a live setup as a standalone device from main L/R to PA. I've been quite happy with it nearly a year. Now it suddenly started to mute the sound in the middle of the playing. Nothing helps but a power up or switching patch via midi. And then we go again another 2 to 20 minutes.
Does anyone share this sort of experience? Symptoms seems to be a bit different from 44.1kHz problem. Many thanks, Jukka |
Re: 11r mutes randomly
No, iv never heard of this.
However, my eleven rack tends to do something that may be significant to your problem, and that is that every few hours my eleven rack's noise gate just glitches and turns off (as in it allows signal to the monitors). It doesn't matter if, when it is glitched, you change the threshold to 0 dB. It stays glitched out until a guitar is plugged in and strummed, or the unit is restarted. Your noise gate could be glitching in a similar way mine does, except it stays on rather than off. Hopefully I helped in some way. Try disabling the noise gate completely and see if it still mutes. Nick |
Do you have the "knob action" set to "jump" (as opposed to "capture")?
(Not sure of the exact terminology, but you'll find it if you look at the global options...) If you do, and the amp is displayed, and the physical knob that controls the volume is turned all (or most of) the way CCW, this could cause the symptoms you're experiencing. IME, the "jump" setting is not useful. It's just too touchy. Another possiblity: Could some device in your MIDI chain be sending a message that the 11R interprets as a mute command (or some other command that breaks the signal chain, such as switching the input source away from guitar)? |
Thank you for your answers!
I run Rocktron MIDI MATE to control patch changes and effects of 11r. This is the only device in the MIDI chain, so if Roctron works as it should there should be only midi messages when I press a button. But muteing of the 11r happened when I did not step on the MIDI MATE buttons. After all this defect might have something to do with 44.1kHz problem. The last couple of times when this muteing happened the 11r has been in cold temperature in the trunk of my car for about 30 minutes before playing. Now I could not reproduce the problem when the 11r has been in room temperature overnight. I have to test this temperature thing too. Jukka |
