Avid Pro Audio Community (http://duc.avid.com/index.php)
-   Pro Tools | First Discussion (http://duc.avid.com/forumdisplay.php?f=138)
-   -   vocal effects (http://duc.avid.com/showthread.php?t=398171)
jucunditas 03-24-2018 09:11 AM
vocal effects
Is it possible to apply Xpand2 effects on vocals?
If not, are there any free vocal plugins for pro tools first that have strange and interesting effects for vocals?, the same effects you'd apply to instruments?
Thanks!
64GTOBOY 03-24-2018 12:01 PM
Re: vocal effects
No to the first question. Yes, all of them in all the other inserts files, pretty much, to the second question.:D
jucunditas 03-27-2018 11:44 AM
Re: vocal effects
Thank you for your reply.
I'm a beginner when it comes to using pro tools first, so please excuse the trivial questions.
On the vocal inserts theres only reverb, chorus, delay but i can't find any distortion or any other interesting sound effects. Are there any free plugins you can recommend?
Thanks!
BScout 03-27-2018 12:36 PM
Re: vocal effects
With Pro Tools First, you can only use the plugins given to you with the program or buy plugins from the Avid Marketplace.
"Buy" so not free.
amagras 03-27-2018 01:58 PM
Re: vocal effects
Originally Posted by jucunditas (Post 2482158)
Thanks!
Don't underestimate the stock plugins, Pro Tools comes with almost everything you need to produce a hit record, some of the names are changed but try Lo-fi or SansAmp PSA 1 for example, those are two awesome distortion boxes.
You could name other of the effect you call interesting and we can tell you under which names you can find them in Pro Tools. Organizing the plugin list by type (this can be done in the preferences page) could help a lot too.
Stig Eliassen 03-27-2018 02:36 PM
Re: vocal effects
PTF included plugins
jucunditas 03-29-2018 01:57 PM
Re: vocal effects
I downloaded a SansAmp PSA free plugin but i can't seem to open it on Pro tools first. Would you know why?
Could you please send me links to download free distortion plugins if possible.
I'm working on an experiment and I'd also like to apply synth type of sounds to voice. The type of sounds you'd find on Reaktor software. Can you recommend any plugins for this type of effects?
Thanks!
BScout 03-29-2018 02:42 PM
Re: vocal effects
Originally Posted by jucunditas (Post 2482438)
To quote myself:
If you want to use other plugins from other developers (like SansAmp) you need to buy a subscription to full Pro Tools. Pro Tools First is free for a reason; it has many restrictions on what will work with it.
amagras 03-29-2018 03:42 PM
Re: vocal effects
Doesn't SansAmp PSA-1 come bundled with Pro Tools First as well?
64GTOBOY 03-29-2018 04:04 PM
Re: vocal effects
No Sansamp comes with Native on up. There are no distortion plugins with free-it has basic eq, comp, delay, dverb and the base audiosuite stuff. To repeat what has been previously stated ONLY plugins that you purchase/rent through avid and avid partners will work/load in PT Free. NOTE: I haven't done it so you'll have to check for yourself but you should be able to do an "In app purchase" through pro tools itself to "rent" plugins by the month to try out. PT free wont recognize non avid partner plugins EVEN IF YOU PURCHASED THEM AFAIK. I have PT Native with hundreds of plugins but if I open PT First on the same machine it will not open any of my non avid/partner plugins(Waves, Soundtoys , etc).
