Click question
Can I set my click plugin in PT to count of 1/8th notes as opposed to 1/4 notes and if so how? Thanks.
Re: Click question
Insert a digirack delay. set to quaver. set mix to 50% (Turn up the feedback level to annoy the drummer:D) Chris |
Re: Click question
hey! don't bug the drummer..he has enough pressure a printed click can be handy sometimes in 7.4 when you want to be in minutes and seconds but still have an eye on the grid lines and you can double up and stagger a cop of that track for a double up an 8th note apart. |
Re: Click question
I am going to try Crizdees method next time though as it is simpler, and one cue mix could be quarter notes, while another could be eighths or triplets (for folks who like subdivisions). Cool. SB |
Re: Click question
HTH... |
Re: Click question
Just click on meter, and change it to whatever resolution (i.e. quarter, half) This way you don't have to double your tempo but the click will double. ;)
Re: Click question
You can option/1 on the numeric keypad and get the time operations window.. and make the same changes, for the "non mousey" types. Goes to show that If I don't use a feature once a month.. i forget it. I am an older model with less RAM, and what I have has been chemically compromised.:D |
Re: Click question
Chris |
Re: Click question
Re: Click question
I'm not in front of my rig, but Elf may be right... it may be the + sign next to the "meter" tab, not the tempo tab. I always get these 2 confused... altering the resolution in one will HALF the click (if original is qtr notes, it'll play back half notes) and the other will double it.... I'll be in the studio in a half-hour or so and I'll check it and get back to ya'.... ..but, to answer your Q, "yes", this is BY FAR the simplest way to play an 8th note click (or 16th or whatever ya want) without changing the session info. |
