Saved my session but lost my audio files?
Hi Everyone,
I was recording drums tonight and saved a session as SongName-Take1, saved it and then did another take and saved that session as SongName-Take2. We enjoyed the first solid take better and wanted to use that but when trying to open it again, after I saved Session 2 it said the Audio files are missing. Should I have saved this in a completely different folder? I thought saving the session would have saved the audio files also. Is there anyway to recover this? Thanks. Lank |
Re: Saved my session but lost my audio files?
Did you "Save As" or "Save Copy In"?
"Save As" uses the same Audio Files, "Save Copy In", as long as you check the box to include all audio files, copies the audio files from one session to another. Cheers, |
I have a feeling when lank says PT saved his sessions he means he can see where the files (grayed out) used to be in the edit window.
Are you sure what drive you saved to? Check in your disk allocation drop down window and make sure these files are NEVER being written to your "C" drive, also make sure "Round Robbin" is not checked. |
